![Image](http://i104.photobucket.com/albums/m161/trevnut/Midweststreetcar4.jpg)
This race will go down at the famous Midnight Drags on August 29th under the lights of Tulsa Raceway Park, one of the best racetracks in the middle united states. This will be a non points, big money heads up small tire race! At this time, we have a 2000 dollar pot with more and more sponsors every day jumping on board! Please let me know if you would like to be a sponsor of this great race.
60 dollars to enter
Here are the general rules and guidelines.....This is a all run race, there will be only 1 qualifying run and that will determine who has the by first round if there is one. The fastest et of each round will get the by if there is one.
1/8TH MILE
2900 small block
3300 big block
74' and older can be 100 light
ladder bar add 100
Modified Street is a heads-up class designed for passenger cars and trucks from a major manufacturer. Big block conventional head with nitrous, non conventional head naturally aspirated only, Small block any head. Nitrous only. one plate only. One nitrous solenoid, One fuel solenoid, One purge solenoid inline. One Nitrous bottle only. Purge must be redundant inline with nitrous supply line with only one supply line. Aftermarket blocks and cylinder heads allowed. Single carburetor only. Turbochargers and superchargers are not allowed. No wheelie bars. IF YOU HAVE A FOGGER ON THE CAR, THE SOLENOIDS MUST NOT BE ON THE FOGGER. 1 nitrous solenoid per car
Rear Chassis suspension
Stock rear frame rails and suspension required. Minor notching allowed Tech decisions final. Aftermarket control arms, springs, shocks allowed must utilize stock mounting points on fram rails. Relocation of shocks with coil over package allowed. Mini tubs are allowed Tech decision final. LADDER BAR UTILIZING THE STOCK FRAMERAILS OK
Wheels and tires
All Vehicles must race on 28 x 10.5 slicks or smaller sidewall designation No W tires allowed. 275 drag radial allowed. Maximum 12'' wide wheel
No wheelie Bars allowed.
General rules
Deep staging allowed.
All vehicles must cross over scales after every qualifying and elemination round.
All qualifying and elimination will be 400 pro tree
Cars will be paired by drawing out of hat
